2000 beetle had no power but idles good :(
2000 beetle 2.0 had no power . Idles good but you step on gas peddle and it wants to die
Default Welcome to Volkswagen Forum - Rules & Recommendations You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out. |
Codes saying misfire have replaced multiple parts
Originally Posted by Keithuk
(Post 66043)
First postsormally go in introductions else you could get a free fix and we never see you again!!!
Catalytic converter , pressure regulator, spark plugs , spark plug wires , fuel filter all have been replaced , no change Default Welcome to Volkswagen Forum - Rules You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out. |
| All times are GMT -5. The time now is 04:04 AM. |
