1998 beetle 2.0 with manual trans
Old Mar 24, 2018 | 05:34 PM
Daughters beetle's Avatar
Default 1998 beetle 2.0 with manual trans
My kid has 1998 vw beetle 2.0 with manual trans. She just brought the car two weeks ago. Now the car is driving really slow and she has to rev the engine at really high rpm's for it to even move. Reverse gear works better than the others, and the car barely moves even then. I don't think it's the clutch as she has to push the clutch in to start the car. The clutch pedal seem fine. and you have to push in the clutch to go though the gears. What could the problem be....thanks.
Old Mar 25, 2018 | 07:40 AM
You posted in General Tech. The title said new member post moved.
Old Mar 26, 2018 | 09:02 AM
thanks alot for responding so quickly, I just went to the new member section to introduce myself. I hope I went to the right area. I wrote down the info you gave and I will check into it thanks again. And I will be back.
Craigs
Jan 29, 2016 08:19 PM
vwconfused
Aug 31, 2012 05:52 PM
chunks3141
Apr 12, 2009 11:07 AM
NickAburg
Mar 3, 2008 02:58 PM
dalpod74
Sep 7, 2007 06:28 PM
