1.8T tranny removal
Hi,
I have a 2001 Beetle with 150,000 miles on it. It needs the clutch replaced.
My issue...how to get the transmission out? I have everything disconnected that I can tell. Tranny moves about an inch back, then stops. I cannot see anything that is blocking the tranny from sliding fully back so I can lower it.
Any ideas?
Thanks!
RRGrassi
Any ideas?
Thanks!
RRGrassi
Thanks Keithuk! That did help, but I must say, whoever designed the setup should have to work on them AFTER assembly. I ended up removing the left side CV axle, and the transmission still got hung up on the sway bar and power steering lines at the steering rack.
Now, I need to find a new clutch inspection cover. I mangled the old one.
The clutch was is very sad shape. No friction material at all. The flywheel and pressure plate are in very poor condition as well. I have a new set up on order.
The ALH is a 1.9 TDI diesel engine and the AWV is a 1.8 Turbo petrol engine. Whether the flywheels and clutches are the same I couldn't tell without searching ETKA.
I don't have any info on the 1.8 APH have you tried Google?
APH vs. APW - VW Forum :: Volkswagen Forum
VWVortex.com - FAQ - -= 1.8t Technical Forum Guide { FAQs | Tuning/Modification Assistance | Troubleshooting } =-
I have no idea where the options sticker is. I bought this car last month to fix up and give to my daughter. None of the online VIN decoders gave me a chassis number. I wish VW does like MB. Like W123, or W126. Those are good chassis numbers.
