'00 Beetle help.
Old Aug 16, 2008 | 03:54 PM
Caitlyn Cataclysm's Avatar
Default '00 Beetle help.
http://i36.tinypic.com/j0co4n.jpg
circled in red, what would you call that part?
I can't seem to think of a good name for it, and I need to search so I can replace it in my bug.
The black housing area, not the vents.
Any help is appreciated.
thank you.
Old Aug 17, 2008 | 10:36 AM
Jrailer's Avatar
Default RE: '00 Beetle help.
sounds good to me
better than the radio cover thingy for the dash vent thingys
Old Aug 20, 2008 | 08:35 PM
mausolfh's Avatar
That is the center trim panel. It covers the radio, A/C and heater controls. It is removed by sliding the center trim extention panel forward (on the top of the dash)and lifting up to clear the clips. Then remove the two screws on the top of the trim panel. Lastly remove the lower two screws and lift the center trim panel out of the way after disconnecting the electrical connectors. This is all done after the radio has been removed; don't forget the code or you won't get the radio working after it is replaced.
