window partially opens itself when car stops
Old Nov 2, 2020 | 07:10 PM
Maps's Avatar
Default window partially opens itself when car stops
Hi,
The car: VW Atlas, 2019, Comfortline.
My *rear* passenger window partially opens by itself for about 10cm (not fully) when car stops, i.e. at an intersection or when I park.
It happens from time to time ,not always.
I also notice that I cannot operate the *front* passenger window as well. and the window lock button does not work.
The car needs to stay turned off for some time for me to be able to close the windows back again and the window lock button starts working again.
Have the car for about a year, took it to a dealer for the oil change about 3 weeks ago. The rear passenger window started to open by itself 3 days ago.
What could that be and how to fix it?
Thanks!
Old Nov 3, 2020 | 08:55 AM
Take it back to a dealer to get it fixed under warranty.
This forum doesn't have an Atlas sub forum thread moved to other models.
Old Nov 3, 2020 | 06:27 PM
Maps's Avatar
OK. Thanks.
I also noticed today that window went down when the door was shut with a force.
The pinch protection went bad?
Old Nov 4, 2020 | 11:08 AM
As I've said.
taxiderek
Feb 17, 2010 03:16 PM
Emma Bane
Jul 13, 2009 03:52 AM
gmbwrenchn
Dec 8, 2008 09:02 AM
youlookfunny
Jun 5, 2008 10:28 AM
eso_rex
Dec 11, 2007 11:50 AM
