VW Fox 1991 not Starting?
Old Oct 27, 2012 | 09:13 AM
Tikkie's Avatar
Unhappy VW Fox 1991 not Starting?
Hi, the car starts inconsistently, mostly just swings. When it starts, if I toggle the wipers and/or flickers, the car cuts out immediately. I removed the faulty alarm and immobilizer, and also changed the spark plugs, battery, coil and fuel pump. Any suggestions? I suspect it might be due to bad wiring
Thank you in advance
Old Oct 27, 2012 | 01:02 PM
There are a few Fox models but you mention changing the spark plugs so it must be a 1.2 or 1.4.
Apart from mechanical failure broken cambelt there are only two reasons why a petrol engine won't start.
1. Insufficient spark to ignite the fuel.
2. Insufficient fuel to be ignited.
You mention removing faulty alarm and immobilizer so it sounds like you have faulty electrics.
I don't recall the Fox being made in 1991, 2005>?
sammk
Sep 27, 2008 10:12 AM
Acesanugal
Mar 5, 2007 09:43 PM
Crossfoxluis
Sep 11, 2006 01:05 AM
palulukon
Jun 25, 2006 01:24 AM
skier150
Apr 23, 2006 02:29 PM
