Possible Voltage problem 2013 jetta hybrid
Old Feb 7, 2022 | 01:20 PM
Galluccit13's Avatar
Default Possible Voltage problem 2013 jetta hybrid
I’ve been experiencing a possible voltage drop however I don’t know what it’s from. I’ll be driving the car and I’ll loose the transmission completely. Then it just throws a check engine and epc light and won’t move until a couple hours later when it resets it’s self.I’ve also tested both the battery and alternator and they are good.
01-Engine Management: 6
02-Transmission: 7
03-Brake Electronics: 5
05-Start Auth-Kessy-Entry: 1
08-Airco: 3
09-Central Electronics: 10
15-Airbag - SRS: 2
16-Steering Wheel Electronics: 2
17-Instrument Cluster: 2
19-Diagnostic Data Interface-Gateway: 2
25-Immobilizer: 2
2E-Media Player Position 3: 2
37-Navigation System: 3
42-Door Electronics Driver: 3
44-Steering Assist (separated): 0
4F-Central Electronics II: 0
52-Door Electronics Passenger: 3
61-Battery Regulation: 0
2B-Electronic Steering Column Lock: 3
51-Electric Drive: 0
8C-Hybrid Battery: 0
OBDII Codes ($03): 2
OBDII Permanent Codes ($0A): 1
P30A100 | Engine Start Interruptions, Permissible Number Exceeded U101700 | ABS Brake Control Module Read Out DTC
U010100 | Lost Communication With Tcm
P036600 | Camshaft Position Sensor "B" Circuit, Bank 1 Range/Performance P091900 | Gear Shift Position Control Error
P044200 | EVAP Emission Control System (Small Leak) Leak Detected
VIN
MAKE
YEAR
MODEL ENGINE SYSTEM LICENSE PLATE ODOMETER
3VW637AJ2DM278500 Volkswagen
2013
Jetta (VIN 9M)
1.4 TFSI
157262 MI
Page: 2 2013 Volkswagen Jetta (VIN 9M) 1.2L MPI (CBZB) Date: 02/04/2022 07:34PM
02-Transmission
54272 | Function Restricted due to Insufficient Voltage-U1400
05636 | Internal Control Module Output Driver IC Error P1604
05636 | Internal Control Module Output Driver IC Error P1604 Upper Limit Reached 06228 | Powertrain Data Bus Hardware Malfunction P1854
05913 | Functionality limited due to Engine Control Module P1719
05940 | Starter Enable from Selector Lever Sensor System P1734
06300 | Function Restriction due to Insufficient Pressure Build - Up P189C
02214 | Tire Pressure Warning Lower Limit Reached
03409 | Rolling Mode recognized
00668 | Supply Voltage Terminal 30 Lower Limit Reached
01325 | ECU Tire Pressure Monitoring - J502 No Signal/No Communication 01315 | Transmission Control Module No Signal/No Communication
U101100 | Supply Voltage Is Too Low
08-Airco
U101100 | Supply Voltage, Voltage Too Low
B10AA31 | Rear A/C Control And Display Head, No Signal D03C00H/13646848 | Refer to OEM repair information for code description
00446 | Function Limitation due to Under - Voltage Lower Limit Reached 00532 | Supply Voltage B + Lower Limit Reached
00979 | Bulb Right Dipped Light - M31 Open Circuit/Short With Power 01315 | Transmission Control Module No Signal/No Communication 01497 | Blinkers Front Right - M7 Open Circuit/Short With Power
01499 | High - Beams Right - M32 Open Circuit/Short With Power
02394 | Parking Light Left Front (M1) Open Circuit/Short With Power
02395 | Parking Light Right Front (M3) Open Circuit/Short With Power
02746 | Bulb For Daytime Running Light: Right Open Circuit/Short With Power 00332 | Control Circuit for Tank Flap Not A Plausible Signal
15-Airbag - SRS
B10B400 | Functional Restriction of Seat Occupied Recognition due to Under voltage
U140000 | Function Restriction Due To Insufficient Voltage U101100 | Supply Voltage, Under - voltage
U111100 | Function Limitation Due To Missing Message U101100 | Supply Voltage, Voltage Too Low
01315 | Transmission Control Module No Signal/No Communication 00532 | Supply Voltage B + Lower Limit Reached
25-Immobilizer
9456128 | Engine Control Module (ECM) not authorized B104A 9456640 | Key: Implausible Signal B104C
Charlesv1982
Mar 15, 2014 06:59 PM
kbob
Jan 12, 2012 07:43 PM
edmundtaka
Jan 19, 2011 03:30 AM
ufodiag2010
Oct 13, 2010 04:27 AM
