VW Cabrio no power to a/c, speedo,tach,and gas
Old May 10, 2018 | 10:40 AM
Noelstone's Avatar
Default VW Cabrio no power to a/c, speedo,tach,and gas
All at once, per my daughter, our 2002 Cabrio convertible appears to have lost power to the A/C along with the Gas Gauge and speedometer stopped working. I've checked fuses and fuse 11&12 don't have any power to them so trying to track down where this fuse gets it's power although. I don't believe this is connected unless it's coming off a relay that happens to control these items. A/C doesn't even start not does the on/off switch light up. At the same time the brake light is staying on but emergency brake is on. I'm interested in any I and where I might find a list showing where each fuse is getting power as good start would be if anyone knows where power to fuse 11 and 12 comes from.
No codes showing
Old May 10, 2018 | 01:00 PM
Noelstone's Avatar
I have resolved the tach, speedometer and gas gauge. Looks like some oil got onto area where speed sensor is so I use air hose and blew that all out and that's on.
Still no power to fuse 11&12 and a/c doesn't work, no light on switch, no blower nothing. I had an extra relay so switched that out but still won't go. Is there another fuse or power connector for a/c?
Old May 10, 2018 | 01:25 PM
Noelstone's Avatar
Looks like it's fuse 3, 7, 8, 11, and 12 that don't have power.
​​​​​​​Passenger side headlight had light out and while replacing I notice most of the wires are exposed due to cracked coverings, perhaps this shorted something out at same time it blue bulb?
Old May 11, 2018 | 06:11 AM
Welcome to the forum.
After being prompted.
Its not really an intro you have posted to problem in your first post.
irishlassie71
Sep 10, 2011 09:38 PM
cpt_ivan207
Aug 25, 2008 02:42 PM
kradschutzen2
Jun 26, 2008 02:09 PM
heavenly_blade101
Nov 29, 2006 09:46 PM
heavenly_blade101
Nov 28, 2006 03:08 PM
