2003 1.8t sandrail project need wiring to fire up motor
Old Jan 4, 2018 | 08:37 PM
Calderon5k's Avatar
Default 2003 1.8t sandrail project need wiring to fire up motor
Hello everyone,
Thank you for taking the time to read this. I am currently trying to wire up a 2003 1.8t manual trans
engine into my sandrail. I need to know what pins to connect to power or what pins I need to connect on the stock ECU. If anyone can help I would really appreciate any help I could get.
Thank you!!
Old Jan 5, 2018 | 08:16 AM
Welcome to the forum.
I assumed your have Goggled this?
Its hard to say without checking ElsaWin, but I need your Type Code.
Old Jan 5, 2018 | 08:47 AM
Calderon5k's Avatar
Thanks for your reply . I am driving to work and when I get there I will add the info to my profile but for now the engine is a 2003 1.8t GTI AWP
Old Jan 5, 2018 | 11:35 AM
Calderon5k's Avatar
I am using the bare motor and trans along with the engine harness. I have gone to the junk yard and scavenged the other half of the ECU harness. I cut it 1ft long. I am now trying to connect the correct pins on the ECU to power in hopes to start the motor. I am still not getting spark on any of the spark plugs. I really need some help on this.
I am aware that I will need to run the stock Throttle pedal and also have the immobilizer removed from my ECU. Those are some hurdles I will overcome after I get the motor to start. I am told that the motor should start even though it still has the immobilizer. I am told it will shut off seconds after it starts.
drewboy96
Jan 27, 2016 07:08 AM
Kristofer Rowe
Dec 19, 2014 06:33 AM
71dartswinger
Dec 24, 2008 03:23 PM
KSURules
Jul 2, 2008 05:24 PM
new beetle fire
Dec 13, 2007 05:11 AM
