Shifter problems - Help!!
Old Apr 24, 2006 | 07:29 PM
d_moser's Avatar
Default Shifter problems - Help!!
Last week my shifter would not engage gears properly. I have a 2k Jetta GLS 2.0L five speed manual. It started with second and fourth gears, but when I got halfway home after work, none of the gears would engage, including reverse. It feels like there are no gear slots (for lack of a better term). I can spin the shifter in a funnel motion. Is there a guider plate under the console that might have slipped out of place or does this mean my transmission bit it?
Old May 22, 2006 | 06:22 PM
ken123's Avatar
Default RE: Shifter problems - Help!!
the same thing has happend to me in my mk3 golf. take off the shifter boot and look at the base of the shifter the selctor shaft is probly broken if it is its about $100 cnd to fix
Old May 22, 2006 | 06:46 PM
p_mister's Avatar
i would agree with the guy above.
if it is just the plate then you could go from 1st to 3rd just not have the glide to it...
tony
Old Jun 8, 2006 | 06:22 PM
stv fox's Avatar
good call broken linkage somewhere standard tranies dont tend to give up without quite a bit of notice
Old Jul 3, 2006 | 01:17 AM
twinsfd's Avatar
I would check the shift ball in the trans linkage, & check for broken bracket that guides shift rod, and buy shift kit to replace worn plastic parts , this is a big item with these trans.
If you wait too long parts will be worn prematurely
DenDenTheMighty
Apr 3, 2011 03:02 AM
clutious
Aug 10, 2007 11:20 PM
01vdub
Feb 6, 2007 09:52 PM
d_moser
Dec 14, 2006 01:28 PM
Ruthies_Cab
Jun 26, 2005 07:13 PM
