obd ii code p1176
Old 01-17-2007 | 03:51 AM
silverbullet's Avatar
Default obd ii code p1176
Ok, check engine light came on...ran scanner P1176 comes up and it states rear o2 sensor correct behind catalyst B1 limit attained....what's causing this? Bad O2?
Old 01-22-2007 | 12:46 AM
red96golf's Avatar
Default RE: obd ii code p1176
either that or a combo bad cat causing down stream o2 issue.
check and see if your running rich witch could cause o2 problems as well
good luck
mike
kettlesing
01-11-2014 07:23 PM
rxxtraquick7
09-30-2011 08:44 PM
shanesch
10-06-2008 11:27 AM
VWZ
08-01-2008 08:04 PM
bobando
10-03-2006 03:17 PM
Quick Reply: obd ii code p1176
