obd ii code p1176
Ok, check engine light came on...ran scanner P1176 comes up and it states rear o2 sensor correct behind catalyst B1 limit attained....what's causing this? Bad O2?
RE: obd ii code p1176
either that or a combo bad cat causing down stream o2 issue.
check and see if your running rich witch could cause o2 problems as well good luck mike |
