Need Help with engine swap please
Hello, just looking for some friendly help. I'm posting this for a friend that forgot to buy the computers for dummies book.
He has a '75 vw bug and just put a 1776cc engine swap in it. The problem is the trans, clutch not engaging. Worked just fine with old motor. He thinks it might need a different shaft for the trans? Hopefully its just something simple someone here may have had a problem with. Any help would be great. Thanks, Brian |
RE: Need Help with engine swap please
they have 2 diffrent clutch plates
one has a coller on it and the other one dosnt same transmitions other than the differnt clutches and through out bearings and the newer trans has a sleave that the to bearing slides on put the old clutch plate on the new motor and you will be fine |
Hey thanks for the help! I did make a mistake, its a '65 not a '75 bug. But I think your right and this would solve the problem. Thanks again.
no problem
let me know if you need anything else |
| All times are GMT -5. The time now is 06:02 AM. |
