Need Good Mechanic Near Cocoa Beach, FL
Welcome to the forum.
If we knew what you drive we could point you in the right direction.
I need a good Mechanic to help me with Error codes?
I took my Hyundai xG300 to get a free diagnostic.
This is what came up:
P1191
P0171
P0174
P1632
P1193
I know this is alot to ask but there has to be a good mechanic out there to help me? I will be so grateful if you could please help me figure out how much this will all cost to fix and if there's anyway I can do it myself?
P1191
P0171
P0174
P1632
P1193
VAG Error Code: 17599
EOBD II Error Code: P1191
Fault Location:
Heated Oxygen Sensor (HO2S) 1 (G39)(G108), Bank 1 & Bank 2 - Interchanged
Possible Cause:
Heated oxygen sensor (HO2S) 1 (G39)(G108) on banks 1 & 2 incorrectly installed.
VAG Error Code: 16555
EOBD II Error Code: P0171
Fault Location:
Fuel Trim (FT), System too Lean, Bank 1
Possible Cause:
Intake/exhaust leak.
Secondary air injection (AIR) system.
Manifold absolute pressure (MAP) sensor (G71).
Mass air flow (MAF) sensor (G70).
Fuel pressure/pump.
Injector(s).
Evaporation emission (EVAP) canister purge valve (N80).
Heated oxygen sensor (HO2S) (G39).
Fuel pressure/pump.
Injector(s).
Possible Solutions:
•In the vast majority of cases, simply cleaning the Mass air flow (MAF) sensor (G70) does the trick. It's best to take it off and spray it with electronics cleaner or brake cleaner. Inspect all vacuum and PCV hoses, replace if necessary. •Check for a dirty fuel filter and proper fuel pressure.
VAG Error Code: 16558
EOBD II Error Code: P0174
Fault Location:
Fuel Trim (FT), System too Lean, Bank 2
Possible Cause:
Fuel pressure/pump.
Injector(s).
Hose connection(s).
Fuel pressure/pump.
Injector(s).
Hose connection(s).
VAG Error Code: 18040
EOBD II Error Code: P1632
Fault Location:
Accelerator Pedal Position (APP) Sensor - Supply Voltage
Possible Cause:
Operating voltage too high/low.
Wiring.
Wiring.
VAG Error Code: 17601
EOBD II Error Code: P1193
Fault Location:
Fuel Pressure Sensor - Open Circuit/Short to Positive
Possible Cause:
Wiring open circuit/short to positive.
mefh777
Jun 19, 2006 06:12 PM
