MultiDi@g Access J2534 not start..
Old Sep 21, 2012 | 03:27 AM
ssali's Avatar
Default MultiDi@g Access J2534 not start..
hello just purchased MultiDi@g Access J2534 from http://www.diyobd2.fr/wholesale/multidig-access-j2534-obd2-interface.html Multi-Di@g Access J2534 Pass-Thru OBD2 Interface my order nr: u212082417952 the program multi-diag access works fine but if I will use the program action workshop ati then that program will not start via shortcut on desktop or must I activate this in the menu off multi-diag acces? Does anyone know ... how to solve it ?
Old Sep 21, 2012 | 05:02 AM
Is there no instruction manual with it, ask the seller?
If the desktop short-cut doesn't work uninstall then reinstall the software or check it properties.
Old Jan 7, 2013 | 12:56 AM
Victor520's Avatar
Member
good!!!!!!!!!!!
Old Jan 30, 2013 | 03:24 AM
billlikecar's Avatar
Originally Posted by ssali
hello just purchased MultiDi@g Access J2534 from Multi-Di@g Access J2534 Pass-Thru OBD2 InterfaceMulti-Di@g Access J2534 Pass-Thru OBD2 Interface my order nr: u212082417952 the program multi-diag access works fine but if I will use the program action workshop ati then that program will not start via shortcut on desktop or must I activate this in the menu off multi-diag acces? Does anyone know ... how to solve it ?
Yes i know this as i have one too
you should according to the instruction, send them the ID
then they can give you keys
i have one technic link for reference
Multi-Di@g Access J2534 Pass-Thru OBD2 Device Technical Service
i followed this and done it
not really difficult
scurling
Apr 20, 2013 01:53 PM
arthgar
Feb 27, 2013 06:38 AM
draganuta
Mar 23, 2011 01:05 AM
Hawkeye59
Nov 23, 2010 07:30 AM
Jeti
Jan 29, 2009 11:12 AM
