Lupo 2003 cambridge
Old Sep 7, 2016 | 02:13 PM
jerdyheinen's Avatar
Default Lupo 2003 cambridge
Hi guys,
I just bought a volkwagen lupo 2003 1.4 with 144000km on it, its my first car but when im driving the oil pressure gives a signal sound+light i checked the oil level which is good.
I think its the oil pressure sensor? Could that be the problem?
Where can i find the sensor and how can i solve the problem?
Sorry for bad english im from the netherlands.
Old Sep 8, 2016 | 06:22 AM
It could be a faulty oil pressure switch but to make sure you need a good quality pressure gauge fitting to check the pressure. The Golf 1.4 has a common problem that the pickup pipe gets blocked in the sump.
Old Sep 9, 2016 | 05:09 AM
I checked everything new oil pressure sensor, new filter, new oil.
Still got the signal from low oil pressure.
Old Sep 9, 2016 | 11:11 AM
I only get the signal when the engine is running between 1500/3000 rpm
Old Sep 10, 2016 | 05:47 AM
Diamond2106
Jun 23, 2014 01:09 AM
daryl
Sep 7, 2012 05:07 PM
Vtec_eck
Apr 23, 2008 01:46 PM
Buttacup
Jan 9, 2007 05:53 PM
cassonian
Nov 22, 2006 09:18 PM
