Jetta Brake Problem
Old Feb 13, 2006 | 07:52 PM
d_moser's Avatar
Default Jetta Brake Problem
The front end shudders when I hit the brakes on my Jetta. The problem is particularly bad on the highway. Any ideas? I think it's the rotors because I recently had the front bearings replaced and it started not too long after that.
Old Feb 14, 2006 | 10:47 AM
Jsd's Avatar
Jsd
Default RE: Jetta Brake Problem
Sounds like you're getting pulsation. Have your rotors machined or replaced.
Old Feb 15, 2006 | 06:12 PM
d_moser's Avatar
Thanks man! I can see odd shaped streaks on the rotors. Do you know what causes that?
Old Feb 16, 2006 | 12:49 AM
Jsd's Avatar
Jsd
I'd have to see them to give you an answer. Usually warped rotors will cause odd lines and pulsation. Check your pads as well. If you're going to replace the rotors or machine them, may as well do the pads if needed.
-Jeff
huyuhy
Oct 8, 2011 03:44 AM
jettagirl
Feb 10, 2008 09:54 PM
c0rndawg
Jul 24, 2007 06:25 PM
golfster
Mar 2, 2007 10:35 PM
X
Feb 15, 2007 02:40 PM
