How to use HIM and HDS to make a forced regeneration of DPF
Old Mar 4, 2013 | 09:43 PM
Victor520's Avatar
Member
Default How to use HIM and HDS to make a forced regeneration of DPF
Hello,
In the french Civic forum, I made a guide to make yourself forced regeneration of DPF.
It's a Google traduction, excuse me i'm very bad in English.
The translated guide:
Presentation:
Firstly, you have to buy HIM Here is an overview:
The link to the page where I buy it (79.99€ free shipping) Honda Diagnostic System HDS Free Shipping
Interface in Diyobd2 , comes with the HDS software (V. 2.006 I think).
Honda interface connects to the PC only on a Com port (RS232), so if you do not have a COM port, you will need an adapter.
I recommend it -> Trendnet TU-S9 à 14.9€ free shipping. It has the advantage of being fully compatible with Windows 7 64bit and it works without problem.
The link to purchase on Amazon:
Therefore, the price of the full interface you back to 94.89€ (77GBP)
You are now in possession of professional tool cheap! Can be used on all our Civic 8)
The forced regeneration:
When performing this?
When you are in degraded mode or with the message "Check system", or if like me, you regenerations too close and you want to limit the damage before it is too late.
Small extra info before starting:
- Make sure you have a PC laptop preferably holding the charge for use 1H or desktop PC on UPS to avoid power cut during the operation.
- The operation takes about 30min. So either you stay in the car while time is still on or off with the PC: not to go back in the car during the regeneration, avoids interactions with it to avoid problems.
- If you use an adapter Com (232) -> USB, verify that the com port is set to COM1. The interface does not work on another COM port!
- Check the oil level before and after regen. If after regen, the oil level is too high or if it stinks diesel will require draining.
- Disable the energy saving usb, antivirus, internet and all that can use PC resources.
The forced regeneration operation:
On this, I appeal to my memory, because I was a bit stressed during the manip and I also fear that my PC crashes battery.
Let's go:
1) Make a nice little tricks with the car to make the 76 ° or at least not too far
2) Put themselves in a place where noise motors can interfere people and nothing can come under the car. (The DPF rises above 600 ° C)
3) Open the hood
4) Disable all that pump energy (ceiling, etc ...) and especially not fun to reactivate during operation.
5) Connect the HIM to the car and the computer.
6) Start the HDS
7) Turn the ignition on II
8) In the HDS, press the "Select a new vehicle" and enter the mileage.
9) Select "System"
10) Select "Diesel"
11) Check and delete the DTC menu "DTC - given frozen". The HDS warn you it is absolutely necessary to remove them before operation and also check the various sensors of the DPF, so if you have a problem with sensors, do not bother going any further.
12) and go back to "Settings"
13) Select "DPF Regeneration"
14) Put the engine running, turn on the lights and put on the air conditioner ON
15) If the engine is not the right temp, the HDS asked to accelerate between 1600 and 2400trs/min
16) When the temp is reached, the HDS takes over, release the accelerator.
17) Allow the HDS to regeneration. The engine mounts alone at 3000trs/min during regeneration, it is stagnant at 1500 trs/min. At the end of the regeneration scheme dates back to 3000 trs/min to cool the exhaust line (weird, but it is like here)
19) When the regeneration is complete, leave the HDS, turn off the engine, remove the cables from HIM and go for a ride to make sure the cooling line.
That is, your regeneration is done and you win a lot of money doing it yourself.
This tutorial may be taken to my next forced regeneration, which I hope the farthest possible.
Old Mar 14, 2013 | 02:15 AM
Victor520's Avatar
Member
what do you think about it? more odb2 tools
Your pushing your luck Victor.
GTIxKiD
Oct 6, 2012 03:13 AM
DADOR81
Jan 9, 2012 12:37 PM
supermarky
Oct 31, 2010 07:42 PM
eriepete
May 28, 2010 11:43 AM
Jettaspeedx2
Sep 8, 2006 10:28 AM
