View Poll Results: Pay more for stronger fuel pump even on old humble jalopy?
Get the cheap one, see if it even works.
0%
Pay more since you drive in the mountains
0%
<Shrug.> See typed response.
0%
Coin toss, go with your gut.
0%
Voters: 0. You may not vote on this poll
Fuel Pump: Is it worth the $$$ for higher gallons per minute? (1999 Mark 3)
Old Oct 6, 2024 | 04:27 PM
OldSchoolJETTA's Avatar
Default Fuel Pump: Is it worth the $$$ for higher gallons per minute? (1999 Mark 3)
Engine died as if out of gas but it's not, fuel pump fuse is good and I am on my way to pick up a new relay. But the fuel gauge was always randomly failing I believe there's a short in the pump so am looking at el cheapos for @ 100, easily pay 2-3x times as much. Will my performance suffer from the lower flow rate of the cheaper versions? It's a standard that I drive up into the mountains a lot but don't know that there will be noticeable difference as the injectors limit the rate of fuel. Any thoughts?
JONR
May 26, 2013 12:52 PM
Toadmanor
Sep 7, 2009 04:57 PM
mullishacrew
Feb 12, 2009 09:28 PM
bobbygouge
Sep 21, 2008 07:48 PM
discolvr
Aug 27, 2008 04:05 PM
