-   -   Flywheel removal (https://volkswagenforum.com/forum/general-tech-7/flywheel-removal-6027/)
Deles136 Jul 12, 2008 11:35 PM
Flywheel removal
How do I remove flywheel from 1969 bus engine? Ehgine is out of bus.
Many thanks
Jrailer Jul 13, 2008 09:46 PM
RE: Flywheel removal
36 mm nut
take off clutch
take off nut
pull off flywheel
Deles136 Jul 14, 2008 11:14 PM
I removed the clutch, locked the flywheel with bolt on devices, used 36mm socket and pull handle and beat the h- out of the pull handle and could not move the nut. I tried the opposite direction and still no movement at all. The locking washer under the nut has never been bent to lock the nut. Can I separate the halves of the case and remove the crankshaft and flywheel? I then could place the crankshaft and flywheel in my lathe ahd cut the nut out of the crankshaft. I think I can buy a new nut for about 14 bucks.
Many thanks,
Jrailer Jul 15, 2008 10:06 PM
you could put a little heat to it
