-   -   EPC and Engine light is on .. (https://volkswagenforum.com/forum/general-tech-7/epc-engine-light-36657/)
Tim Bixby Nov 19, 2014 01:14 PM
2012 CC sport just getting ready to hit 50k.. First is was the check engine light that came on.. Witch found out it was a Coolant sensor.. Recently the EPC light came on with the codes, p2000 p2293 p2185. Any help as to where to look would be greatly appreciated.
Keithuk Nov 19, 2014 06:54 PM
EOBD II Error Code: P2000
Fault Location:
Nitrogen Oxides (NOx) Trap, Bank 1 - Efficiency Below Threshold
Possible Cause:
Wiring/Connector(s).
Nitrogen oxides (NOx) trap.
Possible Solutions:
VAG Error Code: 18725
EOBD II Error Code: P2293
Fault Location:
Fuel Pressure Regulating Valve (N276) - Mechanical Malfunction
Possible Cause:
Power Loss.
Fuel Pressure too Low.
Intake Camshaft Failure.
Possible Solutions:
Check Measuring Value Blocks (MVB) for Fuel Pressure.
Check for bent/squeezed Fuel Lines.
Check Fuel Pressure System for Leaks.
Check Fuel Filter & Filter in Fuel Pump.
Check Fuel Quantity supplied by the Fuel Pump.
Special Notes:
When found in 2.0l TFSI:
Check Fuel Pressure.
Rest of World (RoW) check Technical Product Information (TPI) 2014143, the Intake Camshaft might have a worn out Fuel Pump Cam.
North American Region (NAR) check Technical Service Bulletin (TSB) 2015153 (01-09-03 > 15-10-01 > 15-10-02), the Intake Camshaft might have a worn out Fuel Pump Cam.
North American Region (NAR) check Technical Service Bulletin (TSB) 2018183 (20-08-01) and verify the High Fuel Pressure Sensor (G247) Part Number.
Volkswagen Factory Service Bulletin OBDII Code P2293
EOBD II Error Code: P2185
Fault Location:
Engine Coolant Temperature (ECT) Sensor 2 - Circuit High/Short Circuit to Positive
Possible Cause:
Wiring/Connector(s) short to positive.
Engine coolant temperature (ECT) sensor (G62).
Possible Solutions:
