98 Jetta Cig Lighter fuse location?
Old Feb 6, 2012 | 06:44 PM
Unixxiom98Jetta's Avatar
Default 98 Jetta Cig Lighter fuse location?
My Cig lighter does not want to work and I believe it is the fuse, however I have looked for the fuse under the dash above the relays and I cant find the dang thing. Can anyone explain or have a diagram to show me where I can find this fuse?
Thank you
Old Feb 6, 2012 | 07:20 PM
Well without knowing which engine is fitted its not easy.
Autodata don't list an 98 Jetta only 83-92 and 05-11.
A Jetta (05-11) 1.9D TDI PD
Fuse 42 20A in the fascia at the end of the dash pull the panel off.
Old Feb 6, 2012 | 07:59 PM
I have pulled the pannal down and looked below and above the relays and cannot find it, the engine thats in there is the 2.0 engine and I do not have the handbook for the car
Unless you mean that there is a pannel on the very side of the dash where you have to open the door to get to it??
Old Feb 7, 2012 | 09:38 AM
I did say the panel at the end of the dash. End\side is the same thing.
Old Feb 7, 2012 | 07:16 PM
I looked and there is no pannel the only fuses I see are under the dash below the steering wheel. I have taken the whole thing out thinking there would be the fuse at the very top above the relays like I have been told, but there is nothing there... thats why im asking if posible it is in another location like under the hood or if it looks different form a standered looking fuse.
Old Feb 7, 2012 | 07:31 PM
No panel only fuses, then someone has removed the panel and left it off. The fuse\relay box under the bonnet won't have this.
Jetta (05-11) 1,9D TDI PD 2005-07 Engine code: BRM
Facia 1 fusebox
F42 (20amp) - Cigarette lighter/charging sockets.
6th row down 3rd fuse from the left.
Similar to this.
I've just spotted this. 98 Jetta Fuse panel diagram
And Where is the cigarette lighter fuse on a 97 Jetta?
Old Feb 7, 2012 | 07:51 PM
  #7
Sorry there are no fuses on the side/end of the dash in the 98 Jetta K2 only under the dash and was told in the engine bay
Edit: I believe I found the answer and a diagram after mosing around in some other forums, but thanks Keithuk for trying to help
Last edited by Unixxiom98Jetta; Feb 7, 2012 at 08:06 PM. Reason: Believe I found Answer
Old Feb 12, 2012 | 01:22 PM
  #8
psolarry's Avatar
Default I have same problem
Were did you find fuse?
Old Feb 16, 2012 | 08:42 PM
  #9
From what I found its located under the dash above the relays. [[98 Jetta K2]]
Old Feb 17, 2012 | 12:08 AM
  #10
psolarry's Avatar
COOOOOOOOLLLLLLL!!!!!!! thanks what a pain... my hands barely fit !!!
