71 bug NO POWER, HELP?
Old Mar 28, 2006 | 03:14 PM
jhowell360's Avatar
Default 71 bug NO POWER, HELP?
I just bought a 71 bug with a dual port 1600 and it has no guts and won't even idle right. When going up hill it totally dogs out and has no power. Is this a carbuetor problem or??
Old Mar 28, 2006 | 06:13 PM
p_mister's Avatar
Default RE: 71 bug NO POWER, HELP?
if it is on hills i would say that you might have a problem with dirt or maybe some float problem. i would give the carb a good nice cleaning and see where that puts you at.
tony
Old Mar 29, 2006 | 10:36 PM
bagel's Avatar
try getting some injector cleaner, also, if you have very lil fuel passing through the injectors, it's hard to go fast, also you should really tune it the best you can, adjust the idle if needed, but it's usually a last resort. Remember it's old, and the motor has prolly never been overhauled. Be careful and reserach every maintenance procedure before you do it..
jwrape
Jun 18, 2008 12:34 PM
kyle4201605
May 18, 2008 03:59 PM
firstgear
Mar 13, 2007 03:37 AM
cdawg
Oct 30, 2006 07:57 PM
thoz
Jul 11, 2005 05:14 PM
