2001 eurovan brake indicator light and beeping
Old May 19, 2009 | 03:58 PM
lcjhorvath's Avatar
Default 2001 eurovan brake indicator light and beeping
I need help figuring something out! my brake indicator light will NOT turn off, even though the hand brake is NOT engaged. when i drive, it beeps continuously, and it is driving me crazy! my husband thought maybe the switch was engaged under the cover, but no, it is not. while we are having this problem with the brake light and beeping, the windshield wipers do not work, nor do the headlights or AC! any ideas what could be causing this? perhaps wiring? please help! thanks.
Old May 20, 2009 | 08:53 AM
racerx002's Avatar
You probably need new brake pads up front, they have a wear sensor or you could be low on fluid. If that's not it something could be wrong with the ABS system or the brake booster or the master cylinder.
Old May 20, 2009 | 01:20 PM
lcjhorvath's Avatar
thanks. i know it's not the pads or that indicator and we also checked the fluid level. but thanks for the other ideas too!
fuelslut2483
Jan 5, 2014 12:34 PM
Gemmavine
Oct 19, 2011 07:50 AM
lilyovi13
Apr 26, 2007 10:55 AM
vdub4life
Feb 5, 2007 09:45 PM
CandyAppleJetta
Oct 4, 2006 04:39 AM
