2001 Cabrio Ignition Coil fails repeatedly
Old Dec 24, 2024 | 04:00 PM
Shalski's Avatar
Default 2001 Cabrio Ignition Coil fails repeatedly
My sons 2001 Cabrio GLS convertible Ignition Coil fails repeatedly. I have changed the spark plugs and wires, new distributer cap and button. New Battery. I have replaced the ignition coil about 6 times (different brands) now and the last two lasted about 15 minutes. The last two were similar in failure in that I ensured the battery was fully charged, using a trickle charger, so I know it was at full charge. It started up fine and seemed to run better with the new spark plugs and wires. I drove it about a mile and stopped to check the tire pressure, keeping the car running. After checking all four tires I got in and put it in drive a went 10 feet and it died. When I tried to restart it just turns over but doesn't start. Same every time and if I put in a new ignition coil it fires right up. Can anyone give some guidance on what to check or change? Please help. Thanks!
Old Feb 1, 2025 | 07:35 PM
pijero's Avatar
bri2400
Feb 19, 2011 06:01 PM
jettajim98
Nov 1, 2009 09:23 PM
ihrigch
Feb 20, 2008 05:49 PM
t2evans2000
Dec 6, 2007 10:41 AM
freakngroovn
Oct 20, 2007 08:54 AM
