2000 Beetle 1.8T Fuse 43 blowing
Old 08-05-2011 | 04:08 AM
huyuhy's Avatar
Default 2000 Beetle 1.8T Fuse 43 blowing
I have a 2000 Beetle 1.8T auto and fuse 43 keeps blowing I replace it and it may last anywhere from 1 to 10 minutes. Disconnected everything in the circuit but the 02 sensors and no luck still blowing fuse. It sounds like a relay is picking up and then the fuse blows cant get it to happen when just idling you have to be driving. Anybody had anything like this happen looking for a direction to go next. Thanks
Old 08-06-2011 | 01:42 PM
Sami Jame's Avatar
Chicago based U.S Equities Realty, a facility management company wanted a replacement for it's worn out traditional black asphalt - covered rooftop. After much research they decided on the Clean and Green Roofing solution, an organic rooftop. This new roofing material is surprisingly non - toxic, flame resistant, water - proofed and has high reflectivity. The specialty is that it is able to lower the inside and the outside temperature of the building.
henpeckedpete
04-07-2014 11:00 AM
irishlassie71
09-10-2011 09:38 PM
02-03-2011 12:19 AM
hivoltg
11-30-2007 08:06 AM
Deezul
04-03-2006 05:58 PM
Quick Reply: 2000 Beetle 1.8T Fuse 43 blowing
