1992 Cabrio Problems....
Old Nov 22, 2005 | 11:01 AM
RJE_970's Avatar
Default 1992 Cabrio Problems....
Ok i have a few problems with my 92' Cabrio and i need help pretty fast......
My headlights (low beams), fresh air fan and wipers are all gone bye bye.....
I have replaced all fuses on panel...checked all relays on panel....
What do i do???
Please help...
Thanks
Becca
Old Nov 22, 2005 | 06:03 PM
Jsd's Avatar
Jsd
Default RE: 1992 Cabrio Problems....
wow talk about a random kick in the butt eh!!!
If you've replaced all the fuses...relays...checked the wires? Follow the wires...I find that combination odd...last resort, start replacing wiper motors, fan switch, etc.
If you still can't find the problem I have one solution that will definitely fix your car. Drive it out to a field, make sure no one is around, wire one stick of dynamite to the under side of the car, make sure you have a remote ignition unit. Blow the thing up. Your problem is gone! (okay obviously joking)
Cereal Killer
Nov 28, 2006 12:51 AM
Dajoshman07
May 10, 2006 11:12 AM
yellowaudi24psi
Mar 22, 2006 03:50 PM
kirstie
Jan 16, 2006 08:27 AM
