03 jetta 1.8t misfire
Old Nov 23, 2008 | 01:49 PM
gabewebb's Avatar
Default 03 jetta 1.8t misfire
After the timing belt went, I had my car towed to the dealer for diagnosis. Before they pulled the head they wanted $4500. I found another shop to do they work. Now the car is still in the shop with a misfire in cylinder 3. The coils are brand new, as well as the plugs. When the engine is started it misfires until it is warm. It idles perfectly until you hit the accelerator. It misfires on heavy acceleration and deceleration until the idle resets. The misfire cyl 3 code appears and goes away after idle resets. I've read every post on this forum and nothing has helped or is even similar to the problems I am having. Any suggestions or ideas?
Old Nov 23, 2008 | 10:49 PM
Jrailer's Avatar
Default RE: 03 jetta 1.8t misfire
how is the compression needs to be over 100 psi
Old Nov 24, 2008 | 05:17 AM
gabewebb's Avatar
The mechanic told me all 4 cylinders are the same.
Old Nov 24, 2008 | 02:15 PM
Jrailer's Avatar
ya but at what psi
tc_kannan
May 29, 2010 09:54 PM
ejcunha
Apr 7, 2009 01:10 PM
01silver1.8T
Mar 31, 2009 09:34 AM
jetta jack
Nov 11, 2007 11:40 AM
FearSoPainful
Mar 5, 2007 10:23 PM
