Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
RNS 315 upgrade
Old Mar 19, 2018 | 03:52 PM
Ennio Cavuoto's Avatar
Default RNS 315 upgrade
Hi...this will be the second time I will be doing this to a Jetta...I'm removing the radio/CD player from my 2014 Jetta and will be adding the RNS 315 unit. The prior time I did this (in a 2013 Jetta Wagon), I placed the GPS antenna behind the radio inside the dashboard (per the suggestion of the mechanic that sold the unit to me) and it worked great. I plan to do this to my 2014 Jetta, but I want to add the Sirius radio antenna too. Everything I've read said it has to be outside the car (for best reception) or on the dashboard (for moderate/okay reception). This is the part I do not understand. If the GPS antenna works fine INSIDE the dash, why can't I put the Sirius antenna INSIDE the dash as well instead of ON the dash? They both work off satellites and the GPS antenna has no receptions issues. Thoughts?
Oct 31, 2011 12:50 PM
huyuhy
Oct 17, 2011 11:42 AM
Marty92
Jul 29, 2011 02:50 PM
fred717
Jun 28, 2010 09:12 PM
