Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Help with radio issue please.
Old Jan 30, 2018 | 12:45 PM
kidd2018's Avatar
Default Help with radio issue please.
Hi guys. I am happy to join this forum. Our 2011 vw cc was draining battery and we took it to the dealer and they said it was the radio system. Its rcd 510 premium 8. So they removed the power from the radio and battery draining seem to stop. When the power is plugged, radio works fine though. Any ideas? It take about 7, 8 hours to drain the battery I think.
To listen to music or navigation, i have to plug back the power and unplug at night to keep the battery from draining. I tried to remove the fuse instead but I dont know which fuse it is, but i pulled all the fuse one by one from the driver side when you open the door but that did not turn off the radio at all. Pulled all one by one. Any fix for this? And while we figure out, what fuse can I pull to shut of the radio and what location? Its easier to remove the radio all the time and plug/unplug the power. Any help is appreciated so much.
Old Jan 31, 2018 | 06:58 AM
Battery drain is a common problem that you can Google with CAN Bus.
Old Jan 31, 2018 | 12:25 PM
kidd2018's Avatar
Thank you for the reply. What do you mean by CAN bus? I am completely rookie with this term.
Old Feb 1, 2018 | 05:05 AM
The CAN Bus Gateway, Google battery drain can bus.
Old Aug 23, 2019 | 12:32 PM
paityda's Avatar
Originally Posted by Keithuk
Battery drain is a common problem that Sarkari Result Pnr Status 192.168.l.lyou can Google with CAN Bus.
Old Aug 24, 2019 | 08:04 AM
I have 2012 CC Lux Fuses.
My Fuse & Relays aren't posted in this forum. If you send me a PM with your email address providing it isn't one of the free ones like hotmail, ymail, gmail, yahoo as they don't allow attachments I can send it to you.
kidd2018
Jan 30, 2018 12:43 PM
ZuNuKoo
May 25, 2014 07:59 AM
acsamples79
Aug 4, 2011 07:04 AM
ifpassat
Dec 20, 2009 07:09 PM
vwaustralia
Sep 15, 2006 11:17 AM
