Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
2019 Jetta SE factory default stereo missing fade control
Old Jun 16, 2020 | 12:52 PM
Peter Lammers's Avatar
Default 2019 Jetta SE factory default stereo missing fade control
I test drove a few cars and don't remember if I checked the fader on the stereo for the Jetta I bought. I had an amplifier and new speakers added to the car. They did not remove the stereo as part of the install. The tech says he checked out the balance in the car before he started work and says that there were no fade controls before he started. There are no fade controls now, only left/right balance. We did a factory reset and no change. The rear speakers are connected and working fine. The stereo is the basic one that comes with the 2019 Jetta SE.
Can anyone confirm they have fade control on their 2019 Jetta SE?
Can anyone suggest anything I can check to get my fade control working?
-dm
Old Jun 17, 2020 | 08:31 AM
Does the radio/sat/nav handbook say it should have a fader?
Old Jun 17, 2020 | 11:14 AM
Sorry about that.
Yes, it should have a fade control. Wondering if adding the amp made the rear speakers hidden to the stereo even though they work and play music.
Old Jun 18, 2020 | 08:47 AM
Old Jun 18, 2020 | 11:45 AM
Do I need to do that at a dealership or is that a common thing most mechanics would have?
Old Jun 20, 2020 | 08:49 AM
It depends which garage you use, a lot of garages use a generic scanners as they work on a lot of makes and models.
A VW garage/specialist should have VAG-COM\VCDS.
Your profile doesn't say where you live.
In the UK a dealer will charge £70 just to do a diagnostic scan only with a printout of the results.
VAG-COM/VCDS User Locations
ayoung
Jul 2, 2011 08:51 PM
huyuhy
Jun 27, 2011 03:06 AM
torlev
Jun 27, 2010 02:23 PM
Fasheeryfo
Mar 25, 2008 11:23 AM
parkersgirl
Feb 21, 2008 08:59 AM
