06 keyless entry works sporadically
Old 06-24-2010, 12:19 PM
ericconn's Avatar
Default 06 keyless entry works sporadically
I have an 06 Jetta TDI with under 40k that has had a problem with the keyless entry for maybe 15-20k miles now.
The lock button on the clicker will work only when the car/weather is warm. The unlock button hasn't worked in a while, regardless, though randomly it will work. The trunk and panic work also when warm.
I'm thinking this isn't the clicker's problem but the sensor or receiver in the car. Is that something that can be replaced (fuse/relay)? Where is it even located? Thanks.
10-06-2010 02:25 AM
ErinGTI
09-19-2007 09:57 PM
awl
06-26-2007 10:34 AM
ckyskate0
06-27-2006 01:22 AM
patrick.t.reilly
06-24-2006 08:32 PM
Quick Reply: 06 keyless entry works sporadically
