speedometer on my jetta mk4 quit!!!!
Old 04-10-2008, 03:04 PM
xzacattakx's Avatar
Default speedometer on my jetta mk4 quit!!!!
ok i have a 99.5 jetta with a 2.0....i just bought it and boy do i love it but the speedo is giving me a problem....the speedo completely quit and the odometer stopped too...i changed the vss and still no luck but the weird thing is.....we took the old vss and hooked a drill to it hooked it up to the speedo and spun the shaft and the speedo worked ....we even pulled out the shaft that goes into the tranny with the splines on it and spun it and it worked but after putting it all back together there is still a problem with the speedo.....could this mean that the gear that spins the little shaft that goes into the tranny is stripped or what...or maybe a short ....wont work unless i hook a drill onto it [:@]....i just subscribed here so if you could leave me a reply or an email......my email is xzacattakx@yahoo.com if you can help me please do cuz its all i need to drive it....thank you
Old 04-11-2008, 11:24 AM
bagel's Avatar
Default RE: speedometer on my jetta mk4 quit!!!!
sounds like an electrical problem of some sort. If the speedo isn't working, then there may be a short somewhere in the harness. How long has that been installed?? Check the connection where the wires hook to the dash, see if they're frayed. Maybe a chaffed wire somewhere at the other end. All fuses are good? Not sure beyond that...
Old 04-11-2008, 06:43 PM
Jrailer's Avatar
probably the gear in the trans
i have replaced one on a jetta b4
Old 04-29-2008, 04:35 AM
xzacattakx's Avatar
your right man.....stupid gear is plastic down in there and its broke...taking it to a trannsmission specialist in a couple days....how gay is that...gotta get the tranny pulled just for the speedo....sux
[IMG]local://upfiles/6899/417EBB1E4B8B4C1697BBDC370DC1807A.jpg[/IMG]
msilloh
06-09-2009 01:36 PM
jm777
12-04-2008 08:02 PM
jenks052
10-07-2007 07:26 AM
Wil16679
07-20-2007 04:24 PM
Broke Dub Guy
07-06-2005 11:02 AM
Quick Reply: speedometer on my jetta mk4 quit!!!!
