TDI Boost Issues
Old 09-02-2014, 03:38 PM
hpcrazy's Avatar
Cool TDI Boost Issues
2002 TDI 145K , The injector pump is fresh and to specs, new turbo actuator, new boost sensor, new N75, new vacuum pump, new vacuum lines, new MAF . OK here is the question. Upon hard throttle the boost jump to about 20 lbs then drops back to about 10 lbs then up to about 14 lbs, but low on power. ALL Boost hoses have been checked, the innercooler checked and cleaned, intake cleaned. Turbo was checked all good. Vag Com shows NO codes. GuRu spent labor time $$$ cannot figure it out. Mileage about 30 ish. What the heck is up???? What is left to replaced or check??
P.S. Yes I know the rotator cuff muffler bearing what-u-mac-fuzz-it might need chemotherapy but I don't know where to plug it in.
Seriously Can I Get a real Fix on this?????
Old 09-02-2014, 09:16 PM
mchlandert
07-14-2011 12:25 PM
04-04-2011 11:10 PM
racemegti
11-01-2005 03:27 PM
1lowgli
09-28-2005 04:15 AM
1lowgli
09-23-2005 06:54 PM
Quick Reply: TDI Boost Issues
