Tyre pressure loss indicator synchronisation
Old 08-14-2018, 07:49 AM
Bandit1200Ken's Avatar
Question Tyre pressure loss indicator synchronisation
I have a 2014 Golf GTI Cabriolet and the low pressure warning light has just come on.
Tyre pressures all fine.
Looks easy to reset/resynchronise in the handbook.
Only one problem, no switch in the glove box.
No switch on the central console.
No reset available via the computerised MFD as it jumps from Winter tyres to Service.
Any ideas???
Old 08-15-2018, 07:44 AM
You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check system out.
Post moved to correct section as OP can't read sub forum titles.
Old 08-15-2018, 09:44 AM
Thanks,
Currently no error codes with hand scanner,
I will have a look at the new location.
I had the PD150 for 12 years, great motor:-)
Old 08-16-2018, 07:57 AM
Originally Posted by Bandit1200Ken
Thanks,
Generic scanners aren't much use you need to find someone with VAG-COM\VCDS.
Old 08-19-2018, 02:13 PM
Worst case, 4 new tyres in 2 months time, pre-Winter (after 25,000 good GTi miles ( in 4 years) the tyre supplier will fix it...….. or I will buy them elsewhere
Trtatywe28
09-27-2019 10:24 AM
curtis79
07-23-2019 08:39 AM
Knud
12-17-2017 06:55 AM
James Eaglen
11-02-2016 07:38 AM
Krnata
01-20-2016 08:56 PM
Quick Reply: Tyre pressure loss indicator synchronisation
