-   VWF Help & Suggestion Center (https://volkswagenforum.com/forum/vwf-help-suggestion-center-18/)
-   -   1990 MK 2 Golf 1600 (https://volkswagenforum.com/forum/vwf-help-suggestion-center-18/1990-mk-2-golf-1600-a-341/)
blme Nov 29, 2005 04:40 PM
1990 MK 2 Golf 1600
I need help solving a tech problem for my daughter.
She has a nice looking MK 2 1600 that keeps cutting out at about 8-10 miles and I think it's an auto choke problem.
I have changed air filter but I am not that experienced on these cars.
Does anyboby think they may know why this car behaves like this?
Hoping for a tech answer.
blme
Jsd Nov 29, 2005 05:17 PM
RE: 1990 MK 2 Golf 1600
Sounds like dirt in the float bowl of the carb. If you're not mechanically inclined yourself, you might have to take it to a mechanic. Don't take it to a dealer unless you don't mind paying more for less service.
-Jeff
stv fox Jun 8, 2006 06:15 PM
could be a clogged fuel filter sounds like it is not getting enough fuel you can try a spray carb cleaner if you do have a carb on it ?? I dont think that will fix it but it will run better when you get the other problem resolved
