URGENT!!! VW Transporter 2006 clutch and drive shaft problems
Hi all, Please help URGENTLY. I have a VW Transporter 2006 model. It broke down and we discovered that the problem was the Clutch. We fitted a new clutch and flywheel. As you most probably know, Transporters are known for the problems on the Driveshaft. I took the van to VW and theysaid that the clutch fault caused the driveshaft to go and therefore the driveshaft is not covered under warranty. Has anyone ever experienced this and if so how did you manage? Thank you!!!!!!! |
