Please help me identify this part!!
Hi,
I am not mechanically inclined and therefore need help from someone!!! I recently purchased a 1984 VW Caddy 1300, that was beautifully restored. I have one problem.......the reverse lights are not working!!! It seems that a rather new gearbox was installed with the original motor. I am looking for the reverse light switch and came across this part: https://dl.pushbulletusercontent.com...28-WA0011.jpeg It goes on top of the gearbox. https://dl.pushbulletusercontent.com...28-WA0013.jpeg Could this be the reverse light switch? Or is it something else??? Thank you!!! Enjoy the day wherever you are!!! |
I wouldn't think so as I think its a 2 pin switch.
Switch for reversing light - 020 945 415 A - £15 Flat contact housing with gasket - 357 972 752 - £8.62 1 set single wires each with 2 contacts (in bag of 5, order quantity 5 - 000 979 133 - £2.58 Was dropped on 01/08/2009 for 000 979 133 X - £3.35 VOLKSWAGEN CADDY [CA] (SOUTH AFRICA) 1996: ELECTRICS: 94700. SWITCH - BRAKE LIGHT; SWITCH FOR REVERSING LIGHT; SOCKET; INTERIOR LIGHT; DOOR CONTACT SWITCH; TURN SIGNAL INDICATOR Post moved to correct section. |
| All times are GMT -5. The time now is 02:57 AM. |
