2010 routan won't go into reverse
Welcome to the forum.
Post moved to correct section.
VAG Error Code: 17176
EOBD II Error Code: P0792
Fault Location:
Intermediate Shaft Speed Sensor (G265) - Range/Performance Problem
Fault Location:
Possible Cause:
Wiring/Connector(s).
Intermediate shaft speed sensor (G265).
Engine Control Module (ECM).
Powertrain Control Module (PCM).
Transmission Control Module (TCM) (J217).
Possible Solutions:
nplus8t
Feb 1, 2011 08:12 PM
dirtykurte
Aug 4, 2010 10:18 PM
hipgurl
May 23, 2010 08:40 PM
