2.5TDI Syncro flashing glow plug warning light - electrical problem
Old May 17, 2019 | 05:37 AM
Plus81's Avatar
Default 2.5TDI Syncro flashing glow plug warning light - electrical problem
Hey,
I drive a year 2000 T4 Syncro 2.5tdi and I’m looking to find a fix to the electrical problem it has.
One day while driving the glow plug warning light started to flash and the dashboard backlight went out. Later I noticed that also the small computer screen and the left rear light had gone out, and the battery drains by itself in a few days.
When I start the car everything else seems to work so far but the glow plug warning light starts to flash after some 20 seconds.
I’m in process of trying to get fault codes out with Torque but have had no luck.
What could be the problem? Where should I start to look to find a fix?
Old May 17, 2019 | 07:05 AM
Benjamin Graham
Apr 3, 2019 07:08 AM
jayej
May 13, 2011 02:07 PM
stonky
Oct 28, 2006 08:58 AM
borabora
Jul 28, 2006 12:08 AM
woodbutcher1953
Jun 5, 2006 10:20 AM
