Misfire/running rough
2004 Touareg V6 108,000 miles It started running rough under load and below 3000 rpm. On highway seems ok if I keep it in 5th at around 70 mph. Replaced pcv but no change. Thanjs fir any info on this issue |
Default Welcome to Volkswagen Forum - Rules & Recommendations You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out. Please tell us your car spec in your signature |
