2009 Tiguan - water issues on front passenger side floor
Hi,
I'm having a problem with water on the front seat passenger side of that my mechanic has not been able to fix despite trying several different procedures. So far he's done the following: replaced the tubing in the sun roof that is suppose to drain the water away; cleared out the leaves in the drainage vents in the engine; he took off the front passenger side wheel to see if there was any rust in the wheel well and although there was no rust he found a ton of leaves in there that he cleared out, as such, he thought they might have been causing a 'dam' which prevented water from draining properly and into the car instead. Unfortunately, none of these have worked and my mechanic has given up so I need to find another one, however, before I hit another one up I'm hoping I can get a little more direction or help her. Any tips would be greatly appreciated. Cheers, Mcdonagh. |
Default Welcome to Volkswagen Forum - Rules & Recommendations Sunroof drain pipes are the normal problem but you have checked those. |
Originally Posted by Keithuk
(Post 65045)
| All times are GMT -5. The time now is 08:18 AM. |
