2009 Tiguan - water issues on front passenger side floor
Old 12-17-2018, 10:23 AM
Mcdonagh's Avatar
Default 2009 Tiguan - water issues on front passenger side floor
Hi,
I'm having a problem with water on the front seat passenger side of that my mechanic has not been able to fix despite trying several different procedures. So far he's done the following: replaced the tubing in the sun roof that is suppose to drain the water away; cleared out the leaves in the drainage vents in the engine; he took off the front passenger side wheel to see if there was any rust in the wheel well and although there was no rust he found a ton of leaves in there that he cleared out, as such, he thought they might have been causing a 'dam' which prevented water from draining properly and into the car instead. Unfortunately, none of these have worked and my mechanic has given up so I need to find another one, however, before I hit another one up I'm hoping I can get a little more direction or help her.
Any tips would be greatly appreciated.
Cheers,
Mcdonagh.
Old 12-18-2018, 04:24 AM
Sunroof drain pipes are the normal problem but you have checked those.
Old 12-18-2018, 03:02 PM
Mcdonagh's Avatar
Sorry...I found your site via Google and I thought this was the message board for 'regular folk', as such, I was hoping to come across someone with the same issue.
huyuhy
08-09-2011 04:35 AM
10-27-2010 01:00 AM
Daniellem3176
04-25-2009 08:41 PM
Kimmie
01-18-2008 10:24 PM
jlaman
07-14-2006 02:42 PM
Quick Reply: 2009 Tiguan - water issues on front passenger side floor
