vw polo 2001 air system blocked
Old Apr 8, 2012 | 04:19 AM
gazdkw82's Avatar
Default vw polo 2001 air system blocked
Hi,
my 2001 1.4 petrol polo has had a little problem for a year or so now and i can't seem to find the answer to it.
The breather hose from the button of the engine all the way up to the air intake keeps getting blocked up with a white(ish) mayonnaise like substance.
The other week i took all the air pipes off, cleaned them out, dried them out and did the same with the back box breather (which was blocked full) I cleaned the air intake unit because that was gunked up and put it all back together.
The car was running fine but now its getting blocked up again and its sluggish.
My first suspicion was that there was a hole in the pipe work somewhere letting moisture in but iv checked the system by holding one end of the air flow system and blowing through the other (all the way through the engine) and its defo a contained air system.
Have you got any ideas as I'm pretty stuck now :-/
thanks
Old Apr 8, 2012 | 05:48 AM
This milky sludge is caused by the engine not getting up to temperature to burn this moisture off, it sounds like your doing mainly short trips. You would have to change your driving style to cure it.
Old Apr 8, 2012 | 06:35 AM
gazdkw82's Avatar
I dont do short journeys.
the shortest journey i do is 14 miles to work in the morning
Old Apr 8, 2012 | 06:47 AM
Well thats where this moisture come from. It will also depend on the grade of oil that you use.
Old Apr 8, 2012 | 06:54 AM
gazdkw82's Avatar
i changed the oil and oil filter when i cleaned out all the air system.
I put in 10w40 castrol magnetic
spratty76
Jan 27, 2011 02:55 PM
Missy_Moo
Apr 8, 2010 02:41 PM
RONN_H
Jul 9, 2009 05:07 AM
chris_wadhams
Nov 29, 2005 12:14 PM
