-   Volkswagen Polo (https://volkswagenforum.com/forum/volkswagen-polo-41/)
-   -   Odd Electric Window Problem (https://volkswagenforum.com/forum/volkswagen-polo-41/odd-electric-window-problem-34689/)
Daniel Korben Ryan Stanley 04-02-2012 06:06 PM
I am having a problem with the passenger side electric window on my 58 plate polo Match 1.4.
Neither the drivershttp://images.intellitxt.com/ast/adTypes/4.gif side button or passenger side button operate my passenger side window. Nothing happens, there is no sound from the motor and nothing is jamming it.
However when I remove the fuse and put the same fuse back again the passenger window operates fine if you use the drivers button but only for a few minutes. Then eventully it stops working (i.e. can't be a blown fuse). Have not worked out what stops it working yet, it appears to be a period of time.
The drivers side window works fine. The back windows are manual.
Any ideas what it might be?
Keithuk 04-03-2012 06:56 AM
The fact that you remove and insert the fuse back in and it works for a while it sounds like a power problem. Even if the fuse looks ok put a new one in as fuses can have intermitant breaks/contacts. Check the fuse contacts in the fusebox are clean.
dohamark 01-04-2013 01:50 PM
If you are driving a car, you observe that electric window may have many problems. Either it can not open or close easily. At that time it might be a problem of its fuse or having loose wire contacts.
