HELP!! Polo 6n Wont Start
HELP!! recently joined the dub group by buying myself a slammed polo its the 1.3 carb version.. Anyway after fitting new battery, plugs, leads, rotor arm, fuel pump relay still wont start :( just turns and turns but wont fire anyone??
1 Attachment(s)
Welcome to the forum. Attachment 2918
Do you have fuel and a good spark? If you take the spark plugs out are they wet with petrol? If you push a spark in an HT lead and let the spark plug body rest on the engine to earth, it someone cranks the engine is there a spark at the plugs? https://volkswagenforum.com/forum/ne...gnature-34185/ |
Thanks 4 the reply yes the plugs are getting wet and it has a VERY good spark this is why i am so confused.. Tryed it again today and it really wants to start but just wont go
Really need some help with this guys.. Could it be a compression issue?
Its almost firing its wants to go but just not coming to life :(
Because you've only just had this car so you don't know how it ran before it could be a compression problem, buy yourself a petrol compression tester and test them. It should be 7-15 Bar (100-215 lbs/in).
| All times are GMT -5. The time now is 01:46 AM. |
