HELP!! Polo 6n Wont Start
HELP!! recently joined the dub group by buying myself a slammed polo its the 1.3 carb version.. Anyway after fitting new battery, plugs, leads, rotor arm, fuel pump relay still wont start
just turns and turns but wont fire anyone??
Welcome to the forum.
Do you have fuel and a good spark?
If you take the spark plugs out are they wet with petrol?
If you push a spark in an HT lead and let the spark plug body rest on the engine to earth, it someone cranks the engine is there a spark at the plugs?
Because you've only just had this car so you don't know how it ran before it could be a compression problem, buy yourself a petrol compression tester and test them. It should be 7-15 Bar (100-215 lbs/in).
