Window stops 1cm before top - regulator??
Hi
So i have a 1996 Passat and recently the drivers window has been acting up. It goes down no problem. When i put it up, it stops about 1cm before the top of the window frame and then makes a horrible grinding sound. Sounds like gears grinding. If i grab the window with one hand on either side, i can pull it all the way to the top. I pulled off the panel, and looked around but did not see anything obvious. I have a feeling that the issue is with the regulator, but i am looking for some other opinions to make sure. Any thoughts? thanks!! Ian |
| All times are GMT -5. The time now is 07:45 AM. |
