Water running into passenger footwell - not plenums.
Hi,
I have a 98 1.8 20v estate. It has climate and when I use screen or auto temp I get a flow of water running down the carpet on passenger side. I guess it's the air con condensor , is there a drain pipe hidden? Is it easy to get to? Have used search but only found the plenum info so hoping someone has had same issue and knows a fix Cheers |
| All times are GMT -5. The time now is 03:20 AM. |
