vw Passat coolant question? Please help?
Old Nov 16, 2008 | 04:18 PM
humphreycharles2000@'s Avatar
Default vw Passat coolant question? Please help?
Hi i have a 1998 VW Passat, the check coolant light cam on yesterday, i pulled over and checked the coolant and it had boiled and spilled over as i took the lid off. I topped up the coolant and it was ok for a while. However i just drove 10miles and the temperature level was near 260f and the coolant light was beeping. I need to drive to work tomorrow before i can drop it off at the VW garage thats 30 miles. Do you think i will be alright to drive 30 miles if i take regular stops? or will this totally mess up my engine?
If anyone has any ideas i would really appreciate your help or advice!
thanks
John
Old Nov 16, 2008 | 09:05 PM
Jrailer's Avatar
Default RE: vw Passat coolant question? Please help?
keep a eye on the guage
Old Nov 18, 2008 | 07:36 PM
01boostedb5's Avatar
i dont know if im too late butit sounds like your water pump went out, and i would not drive it, check to see if your heat works, if not, its more than likely the water pump
Old Nov 18, 2008 | 10:47 PM
Jrailer's Avatar
good call boost
Alex5357aa
Nov 1, 2012 12:38 PM
92929292
Aug 16, 2012 03:41 AM
Gewing4
Sep 27, 2011 01:14 AM
reganald31
Apr 23, 2008 09:17 PM
spilo
Jan 4, 2008 08:45 PM
